Outside Temp Sensor 2011hd
when I'm moving I saw 75 today but it was snowing and 33? once I pulled into my drive it went back down. I could have sworn I saw a thread on this issue
Do you have a rad-cover installed ?
I turn off the temperature display in the winter time due to the rad-cover.
Mine will do that temporarily if my truck is sitting in one place too long idling but once I start to move it's back to normal within a couple of minutes.
Global warming... :lol:
It's your plow.....drop it lower if you can, you'll see it change. I know mine read 135 degrees one day during a snow storm...
your right I took the plow off and its fine now, but I got the plow pack you would think they relocated the sensor just for them
Not an expert, but I believe the plow creates a vacuum under the truck, and actually "reverses" the air flow in the engine compartment, so the radiator heat is passing over the sensor.
Mine just did the same thing yesterday, was 44 out and display said 55. Drove about a mile down the road and finally started reading correctly, without the plow on. I seem to remember my 02 Sierra doing the same thing.
    2022LtTbZ71
    2022LtTbZ71
  • Who's Online   3 Members, 0 Anonymous, 1,109 Guests (See full list)
