1993 Chevy Pick Up
jerseywithk
Battery drains overnight on my 93 CK pickup. Exept when it's in the technician's shop. I've isolated it to the courtesy light circuit by using a 12v trouble light connected between battery negative terminal and ground. Pulled all the fuses one at a time, and when i got to the courtesy light fuse, the trouble light quit glowing. Also, I do not have the battery drain as long as I keep that courtesy light fuse pulled. Local technician said he couldn't find a drain. Said he put the courtesy light fuse in and it started every day he had it (9 days). Also said he did the ground/drain check and did not see anything. Maybe he did but I remain skeptical. Regardless, the courtesy lights appear to work fine...they fade out once doors are closed. So for now, i've got the fuse out to keep the 3 mos. old battery from draining overnight. One thing I'm wondering is if "locking" the steering wheel after pulling the ignition key affects the drain. Maybe the Tech did not lock the wheel like I do and there is a short in the column that is associated with the courtesy light circuit. Any assistance is appreciated. Ed in Arkansas
  • 4 months later...
I have exactly this same problem, minus the mechanic shop. I've been told that since my voltage gauge bobbles when I turn on the turn signals that there has to be a short in the column. I could not isolate it via the method you described. I pulled every fuse one at a time and it remained on. I've heard there are relays that can be stuck, but have yet to find any evidence of that. Would be great to figure this out.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
