Failed Emissions Test
webstri
Hi,
Ran my 1998 gmc yukon thru emissions test and failed. Two codes: P420 and P430. Catalytic converters were replaced 3 years ago.
What parts do I replace to eliminate the two codes?
Get it diagnosed first. Just because an o2 sensor code is set does not mean that the O2 sensor is bad, in many cases, it's something upstream that is causing the readings to go bad once the exhaust hits the sensor. Throwing parts at something hoping it fixes it wastes more money. Take her into a good reputable shop and have it diagnosed.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
