Interesting: All Terrain Grille
Hey... I was looking at pics of members All Terrain Sierra's and I noticed something. Most of the pics I saw the grilles have the chrome bar across the top of the grille, just like my 3 bar plastic grille.... but some of the trucks I saw didn't have the chrome bar, it is just empty. Is this an option that some All Terrain's got and some didn't? Or maybe the owner's removed the piece..... just wondering what came stock from the factory when you ordered an All Terrain
Here's a few pics to show what I am talking about.. if the owners of these trucks could post that would be great
With the chrome bar (look at my sig as well)
Without the bar..humm... or is it that the bug deflector covers the chrome top piece?
It's covered by the bug guard
I recently was at the GM dealer over in Whitby and they have 6 or 7 GMCs W/Ts with the chrome surround on the grille itself, but the black surround on the hood. They also did not have the painted upper bumper, they were black as well. Looked odd to say the least. Not sure if they simply installed the leftover grilles from the 2010 that were upgraded to the optional chrome grille here last year for free or not. Looks like that is what they did. In Ontario last year GM was giving the chrome upgrade package for free (chrome mirror caps, chrome door handles, chrome grille, and chrome running boards). And since these were dealer installed, the original parts were still brand new and unused.
Thanks for the replies... I thought that as much but wasn't sure.
Hey Doug....I think you are right about the chrome surround grilles on the W/T's. Here in St. John's I know for a fact that the GMC dealer takes all of the chrome surround grilles with the 3 bar black plastic that are taken off say the SL/SLE models which get upgraded to the chrome "Denali knockoff" grilles and sells them to smaller used car/truck dealers around the island. I think that "technically" they are supposed put all of the grilles into the recycling bin but off course that doesn't happen. Some of the GM technicians take them home as well. My father inlaw bought a 2010 W/T Sierra and we replaced his black plastic grille with a chrome surround one, but it looks odd because the top piece on the hood is still black (we're working on getting him a chrome piece)....
Cliff Mills in Oshawa is selling a bunch of take-offs for $100 a pop, not sure what all they have but it might be a good place to p/u a Terrain or Denali grille?
P.S. Are you the Doug Scott who repairs hot water tanks and the like?
Nope, but since you mentioned it, I have lived in this area for about 35 years now, and I only just saw that company van last year for the first time, and since then many of my friends have mentioned seeing it. He must have just put the company name on his trucks recently.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
