Bluetooth Pairing
Has anyone tried to pair the new HTC Thunderbolt on Verizon's network to their GM bluetooth system? Just curious if it has issues like the iPhone 4 now offered by Verizon but needing an iOS update from Apple before it will work on the GM vehicles. I called Apple today and they could not provide any update as to when the phone would be updated to work with GM bluetooth. Apparently the iPhone on AT&T work great, it's just with the iPhone on Verizon's network that won't work properly. Thanks Apple.
I believe the Thunderbolt is using the Gingerbread based Andriod OS so it will be different than the X. Can't say for 100% though as that is just what I read. My X pairs fine on all GM bt applications but it only has the 2.2.1 OS.
The thunderbolt is still on Froyo (2.2.1 - I just looked at my thunderbolt to verify) and should pair up fine.
I paired a friends Thunderbolt today after work and tested it with the Bluetooth system and it worked fine.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 402 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
