My New Silverado
From 1989 to 2002, I drove a burgandy-colored 4x4 GMC Sierra with a regular cab and short bed (along with a Warn winch on the front). From 2003 to early 2011, I drove a Dodge Durango. While the Durango is a solid SUV, I really missed my old truck.
About a month ago I was forced to buy a new vehicle after my wife's car was totaled. So we decided to get another truck. I came close to pulling the trigger on a 4x4 Sierra crew cab, but we made one last visit to the Chevy dealership "just to make sure" the Sierra was what we wanted.
Well, the Chevy dealership had what we were looking for, and gave us a slightly better deal on a black 4x4 Silverado (5.3 liter) crew cab.
The whole family has been very impressed with the new truck. My wife can hardly believe how much she enjoys driving a truck. And my young daughters love "Daddy's truck" and all room we have in the backseat compared to the Durango. Compared to my old Sierra, it really has a smooth ride. I haven't used 4WD yet, but we are planning a visit to my friend's swamp house soon, where there are plenty of muddy roads.
Here is a picture from the dealer's website before I bought it.
Welcome, these trucks will make you realize what a pos an old durango was haha when I hear swamp I think Louisiana for some reason, where are you from?
Thanks guys.
Yeah, I don't miss the Durango at all. My wife drives it now, but manages to "borrow" the truck every morning to take the kids to school before I have to leave for work.
I'm from SC. We don't have anything like the bayou, but we've got some decent swamps around here. My friend's place is near the Congaree National Park.
this is the before photo. ill have my leveling kit and body lift soon as possible! And yeah my wife loves the new truck as well but im a little luckier in the sence that she is intimidated driving big trucks so yay for me, and the life of my truck!!!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
