Vapor Canister Saturated With Fuel
festx
Friday I noticed a very strong fuel smell coming from my 1986 Suburban C10. I popped the hood and saw that gas was dripping from a fitting on the air cleaner vacuum line. I trace the line back to the vapor canister. When I disconnected the line from the vapor canister it was under high pressure and gas spewed everywhere. I quickly reconnected the line so that fuel wouldn't continue to go everywhere. I know that the fuel tank vents into the canister so I slowly opened the gas cap. That too was under higher pressure than usual (lots of hissing). I cant remember the last time I filled the tank completely so I know it's not the common over-filled fuel tank problem. All the vacuum lines appear to be hooked up with no leaks. I'm wondering if it's just a matter of replacing the purge valve and canister, but before I drop $150 I thought I'd just throw this post up to see if anyone has experienced a similar issue.
Ok, after some tinkering around, here's what I think is happening. I started the suburban and drove it around until warm. I popped the hood and pulled the hoses from the canister one-by-one. The PCV hose was dry (expected), and the carb bowl hose was also dry (which means the carb is not the source of the fuel in the canister). When I pulled the air cleaner hose off the canister gas was spitting out, so this means the source of the fuel is the gas tank vent hose (the only hose I haven't pulled yet). When I pulled the gas tank vent hose, I observed vapors only coming from the hose, not liquid gasoline. I think the purge valve or canister is malfunctioning, or both, causing the vapors to condense in the canister rather than purged and re-burned by the engine. I'm going to replace the purge valve and the canister this week. Unfortunately, these parts are not carried by local parts store, but I found the purge valve for $10 and a new canister for $37 on rockauto.com. The only other thing that I can think of that might be causing this is a bad fuel tank cap.
Put a new fuel tank cap on it.
No dice. I just changed the fuel tank cap and it's still happening. High pressure building up in fuel tank and the canister is saturated again.
As mentioned in my previous reply, replacing the gas cap did not resolve the issue. It was worth a try though. It was only $8 and the gas cap that was on there looked the original. Anyway, before I drop some more $ trying to resolve this issue, I just want to confirm that what I am looking at under the hood is what I think it is. The Haynes manual does not have an picture of the purge valve and it's location is not clear to me.
- What is #1?
- If #2 is the decelerator valve, then is the purge valve built into the vapor canister?
- Is #3 the Thermal Vacuum Switch? If so, is it possible that it's malfunctioning preventing the canister from being purged causing the fuel vapors to condense?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
