285's VS. 305's
Thinkin about getttin a 3 in. body and either 285's or 305's on the Hoe...im tryin to see if there is a significant difference between 285's and 305's on a student's gas card...thanks
285's and 305's are just about the same hieght, but the 305's a slightly wider, so you'll have a bigger contact patch on the ground.  The 285's might get slightly better gas mileage, but I really don't know if it would be a very noticable difference between the two.  :cheers:
I have never run 285's,I run 305's so I can't really say,but I agree with Tom,don't think the mileage would be much different since they are pretty much the same height.
one thing i would think about is how the wider tire will throw junk up on the side of your truck
wider tires = more rock chips
And w/ the flares there wasn't any added worries of rock chips
I have 285s and factory flares and mudflaps and i still get my share of rock chips in the rear.
It might help but it wont stop em
I don't think you will notice much difference. Your stock 265's are almost 32 inches tall and 285's and 305's are almost 33 inches.
anyone got a pic of a tahoe with a 3in body and 305's or 285's..ive seen all the silvies...and sierras with them...just tryin to get a proportional look at things
Heard of any cooling problems with new style chevys and body lifts...since the fans are 3 in higher than the motor?
I've run 285's and 305's and the difference is about 1" of width...gas mileage is the same...if you have a narrower rim the 305's wear out faster than the 285's do but it is marginally faster so go with what makes you happy..
I havn't heard of any, but I did a little work to mine.  I didn't have any cooling problems, I did it mainly to "clean it up" under the hood a little.  I think what I did helps the fan shroud to now work more like it's suppose to before I added the B/L.
Before:
After:
More pics here.  Fan Shroud
    Charly
    Charly
  • Who's Online   2 Members, 0 Anonymous, 3,231 Guests (See full list)
