Knock Saensor?s
i have a few questions pertaining knock sensors. i have an 06 vortec max silverado and the truck sometime acts like its in limp mode and its either the after market tune on it or the knock sensor. what do knock sensors do when they stop working? do they throw and engine light always when they r bad? and do they come in and out when going bad or do they just completely go bad?
thanks for any responses
John McDaniel
im not 100 percent sure but both mine were bad. they threw a code for bank 1 and 2. bank 1 is the sensor in front towards the water pump. i think if they are bad they throw codes but im thinking if they are good then they adjust when u dont even know it. like i said im not 100%
