Finally Got My All-terrain Cupholders
  • Replies 62
the aluminum trim is one of the reasons i bought the all terrain to begin with! looks much better than the wood grain IMO
Actually fake woodgrain. Real burlwood looks quite nice. I had it in several Mercedes cars.
I love the stance of your truck. I have to get mine looking like that.
WOW, I ordered my real live fake-burl wood plastic cutholder unit on Wednesday and it came today. Two days, from Houston to Portland, Oregon must be some sort of record.
This online seller I ordered from is Conquest Auto. They weren't the cheapest, but return was not a problem. http://www.conquestauto.com/product_p/25912889.htm?click=2
Several of the E-Bay azzwipes said "Don't even bother ordering this if you have any questions about it being the right fit. NO RETURNS." That attitude cost them my order. It never pays to insult the buyer.
The first two photos are of the original black plastic cupholder unit.
And below are the are the photos of the new cupholder unit in place.
All in all I am very pleased with the transformation. I think that it makes the interior of the truck look much more luxurious than the cheap bucket that comes standard on these trucks.
I have to agree, I think it looks great. I think I will have to look in to that. Is the color an exact match to the bezel around the stereo?
It is a bit of a pain in the ass that the cup holders are not removable for ease of cleaning; you have to pull the whole bloody thing to throw it in the sink.
As far as I can tell it matches the stereo surround exactly.
This is the biggest draw back. I guess if someone tends to spill or doesn't wipe them down regularly they are a big pain. I used to throw the other ones in the sink with dawn soap if they got any kind of sticky drink on them, but now I can't. I just find myself wiping them down when I wipe down the rest of the interior (every other day).
Anybody have any feedback as to whether this All Terrain cupholder will fit in an 07 Yukon XL?
I went to gmpartsgiant.com and when I keyed in my VIN to check compatibility with my truck it came back saying it wouldn't fit. :(
I'd like to add this as I'm tired of the huge black bin.
Any assistance would be appreciated.
I am pretty sure that it would fit. I think that the problem that you are having is that the part is actually for a Sierra, but the Yukons have the same cut-out for the bin as the Sierras do
  • 1 month later...
Turbo 810...
Does the brushed metal finish match the other brushed accents on your truck....ie: ac center vent, horseshoe shaped brushed piece under radio in center?
Thanks.
Mine showed up today. I like it much better.
The rubber liner comes out of the cupholder portion for cleaning ... you don't have to take out the whole assembly from your console for cleaning ...I have an AT and clean the rubber liner all the time. It's simple.
Turbo 810...
Thanks.
Mine is an LTZ. So I have the wood grain. The cup holder matches the wood grain and not the brushed finish. Sorry I can't help you out.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 413 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
