"service Battery Charging System"
On a short trip today, the red "Battery" symbol on my dash was illuminated, and the DIC showed the message "Service Battery Charging System".
Voltage gauge showed about 15 volts (above the 14V mark but not up the the next un-labled mark).
After the trip parked the truck for about an hour, and when I went back out the light and DIC warning did not come back. Voltage guage still up in the 15V area.
No codes.
What's up?
(And does this alternator have an outboard voltage regulator?)
On an '08 the ECM controls the voltage. If you ever watch it you will see the volt meter you will see that when you fire the truck up it will sit low (12 volt ish) to start while the glow plugs / intake heater do their thing, how long depends on temp. Then it will ramp up to near 15 volts to charge what was used, after that it drops back to just under 14 volts. This is the normal cycle.
What you describe sounds like it senses that the batteries where taking longer to charger than normal. This could mean two things IMO, 1 - you did something to drain the batteries more than normal, 2 - the batteries are on their last legs and it is time to replace them. Given the fact that we are talking about an '08 and 4 years I would choose #2.
Did you add the second battery or did it come OEM? I would get this warning on my Tahoe with dual batteries every once in a while and it turned out to be since the 2nd battery didn't ground through the current sensor of the original battery (the plastic ring around the ground wire). I redid my wiring so that both grounds merge and then ground through the current sensor. It got progressively worse so I'm guessing as the older battery deteriorated a bit the unequal current cause cause a code. I haven't seen it since but I also switched out all the high current wiring for heavier stuff.
It is a diesel, the come with two batteries and they are wired in parallel, so they are both active all the time.
I would pull 1 battery out at a time and load test to determine if they are about to fail.
Keep 1 battery in to keep all the computers powered and happy.
Batterys test ok then I would then check the volatage regulator then the alternator then start looking at drain in glow plugs / grid heater has become excessive and is drainging your batteries below the threshold of the computers comfort zone.
I've noted last few weeks of winter the glow plugs seems to take longer so my batteries may be going south as well. or glow plugs are showing wear.
I hope this provides some quideance to your problem/s :banghead:
Oh, also forgot. There are several Mega fuses on the firewall, passenger side. One of them is the fuse for the alternator. There have been several reports of these fuses being loose and causing charging problems. Good place to check.
    • Are you going to take long trips in it?  If so, try out the seats in the various trims. For me the lower trim level seats were not comfortable.
    • I have a 2016 that I bought new and still own. I'm around 129,000 miles now. The biggest problem was a transmission failure about 2 years ago around 95000 miles. No warning, just failed while driving down a back road. A reman GM transmission installed and it's been fine ever since. A few other minor problems along the way. I am in no hurry to replace it. It's been paid off long ago and do plan on driving this as long as I can.   I will admit I am leery about all the additional electronics in the newer models and feel that it is just more potential problems. I think there's actually more than I would have wanted in this 2016 but so far so good. I think even if something major like lifter failure happened, it would still be cheaper to at worst, drop a new engine in than buy a new vehicle.
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
