My Truck Died
jwd2184
I really need some help here. I drive a 2001 GMC Sierra 4.3L V6 with 225,000 miles and it runs great. I was coming home from work which is a 45 mile drive and about a mile before my exit I lost acceleration as if I ran out of gas. I then quickly exited and the truck died. I filled up two days prior plus I had a gas can with me, so gas is good. The truck would turn over but would not start. Keep in mind I had the P0446 (Some thing with the EVAP system) code come up with the Service Engine Soon about 3 month prior to this. Here are the things I done.
Checked for a spark, spark is good.
Checked the Coil with a meter in accordance with the manual and against a new coil, coil is good.
Had the ignition control module checked out at AutoZone 4 times in a row. That's Good.
Replaced fuel filter, during replacement I didn't notice pressure in the system.
Checked that the fuel pump is coming on that's GOOD. Haven't checked fuel pressure I believe it should be 60-66psi
Replaced plug wires
Currently working on cleaning out the vent valve to correct the P0446 code. Trick I read in other forums
I found a Technical Service Bulletin PIP-4695 NATSA # 10032435 which resembles my issue but no solution.
Thanks in advance for any suggestions
i'll try to remember to check my repair manuel for the proper fuel pressure for the 4.3...i know its not as high as the v8s
You all seem to be correct, fuel pump. I'm only getting 10 to 13 psi off the valve and should be getting 60-66psi. There are two different part numbers I could use E3500M which is a single electrical connector and E3501M which is a dual connector. Any advice on this? and where I could get the cheapest fuel pump? Thanks for your advice.
Cheap fuel pump = doing this same repair over again soon.
I only use GM/AC-Delco/Delphi fuel pumps, even at home for side work, exclusively because of this.
Where can I find the best deal on any of these brands?
Do you drop the tank or do you remove the bed? I was thinking removing the bed.
RockAuto.com has tons of them. When I replace this I'll be killing two birds with one stone because my fuel guage hasn't worked in over 4 year, so I'll need one with the sending unit. Any suggestion on what not to pay for a fuel pump? What is too much for a fuel pump?
neither, do it like this. Less than an hour not counting rewiring a new connector.
search for MU1089 on ebay, I got a AC-Delco for $175
doing it this way, you don;t have to worry about if your tank is full or not.
    MANGOAL
    MANGOAL
  • Who's Online   1 Member, 0 Anonymous, 372 Guests (See full list)
