18x9 Centerlines $149!
I just ordered my wheels from Centerline's overstock deals. I got 18x9 chromed Turbines with 5" backspacing (0 offset) for $149 a wheel. The guy on the phone said they had 8 wheels in stock when I ordered mine. I plan to order some 285-65-18 Trail Grapplers here shortly. I'm still undecided on which leveling kit I'm going with. I'm pretty stoked about my new rims though!
Just to forewarn you if you are anywhere near salt or other contaminates. DON'T let the wheels get exposed, they will pit and it is very hard to get them polished, my dad "lost" his new rims after only a month (they were waxed and washed a couple times as well). So now we spent hours repolishing them and they still aren't prefect and have small pits and then once we got them as good as we could we had them powder coated with clear powder. So it was a huge lesson learned ($250 for the PC $80 to have them stripped on top of the $1100 set of rims).
Sorry if that sounded bad, but this hasn't been a good deal.
I've had two sets of polished wheels like that. I got chrome this time so hopefully I wouldn't be hunched over my wheels for hours on end. I've been there, starting at 400 grit and working up to 1200, before finally polishing with Mother's and microfiber. I'd like to believe that chrome won't be as maintainance intensive. I can dream right?
Let us know how they turn out,I have 18 x 9 wheels with 0 offset and 285 65 18 tires with a 2" levelling kit and the tires rub on full lock when backing up.
Thanks for the heads up Mitchell. Do they rub the back of the fender liner? I had planned on a 2.5" kit, and trimming the rear of the fenderwell if needed. A picture would be awesome.
I won't know how it's all going to shake out for a couple months since I'm deployed.
  • 3 months later...
Just to give you head's- up, I bought a set of the chromed CenterLine wheels and less than a year I had to pay shipping and to have the tire's taken off because the chrome started to pit and come off. They kept my wheels 3 month's when they were to ship them back I talked to the Mgr. and he said whatever happened to these wheels came back through the new chrome. At that time he told me to pick out a new set of wheel's, I did and another 3 month's later I got them and had to pay for mount and bal. again. By the way I picked out a Polished wheel the second time.
The moral to this story is you have to really take care of these wheel's like other people has posted also. I really do like my wheels and would buy them again. Hope this helps in some way!!!!!
LURCH!!!!!
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
