On-star Diagnostics
I received my last diagnostic email from On-Star around mid March. When I check my account on their website, it shows the last readings were in March. I drive the truck at least once weekly, so there's plenty of time for them to query the system. Has anyone else had issues?
they don't query the truck, your vehicle is programmed to transmit within 72 hours of its activation date, i.e. I bought my truck on the 21st and activated OnStar on the 22nd, so my transmit date is the 22nd of every month, and it will transmit within 72 hours of that date (as told to me by the OnStar 3rd tier techs when I was having issues with my OnStar a few months back)..
It will also not transmit if you have anything plugged into the OBDII port during it's scheduled time, I have a UltraGauge (like a scangauge) and while it is plugged in I don't get any Diagnostics..
in addition to all of that, OnStar sent me an email that they had network issues in April so diagnostics may be delayed or not be available, if I required one I could press the OnStar button to request one, the email did hit my spam filter so had I not checked I would never have seen it..
So by that reckoning, if the truck remains off during that 72 hour period, it will wait until the next anniversary date to upload diagnostics? That kinda makes sense. :jester:
Yeah as it was explained to me it can happen up to 72 hours after that date but won't happen before. And if the truck isn't active for those 3 days it won't happen until next cycle.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
