'07 Classic Parts Help
Hey guys, I have a 2007 1500 silverado classic. I wanted to get some parts for my truck and didnt know what parts I should get. I was looking around on summit and jegs and saw that they have one part listed for a 06 and another part listed for a 07. Since I have a classic which parts should I be looking at?
Things I wanted to get are, KnN intake, Front 2" reciver, Exhaust, and a few other parts...
Does anone who has a Classic know of what parts will or will not fit?
Ok, so "06 intake kits should work then.
Anyone have a classic with a intake kit?
There is no difference between the 06 and 07 classic trucks. GM just carried over the production run of the GMT800s while they were getting the GMT900s ready.
There are some differences but they are small. A example is the oil filter, it is different on a 07 vs. 06.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
