Which Offset For These Wheels?
http://www.mambawheels.com/Mamba_Wheel_Lin...mba_Type_M7.htm
I'm looking to get these in an 18x9 for my 08 Silverado 4x4 Graystone Metallic crew cab. I have a RC level and dont plan on doing any other type of lift at this time. I'll likely wrap them in a Nitto Terra Grappler 285/65-18 or 305/60-18.
These wheels are available in a +30 and +12 offset. I know the +12 will obviously stick out 18mm more than the +30.
Would the +30 be better since its basically factory offset, even though its a wider wheel?
Would either be more condusive to allowing the 305/60 to fit without any major trimming? I don't mind trimming a little plastic if needed.
Which off-set would you recommend?
Thanks in advance!
Go with the +12. It will look better and you should not have much rubbing with either tire.
Many guys run +18 with both of those tires with no problem. Same thing as 20x9 with 285/55 or 305/50.
    overspeed
    overspeed
  • Who's Online   2 Members, 0 Anonymous, 1,044 Guests (See full list)
