2000 Chevy 1500 Air Conditioner Woes
FriendlyMan
I have a 2000 Chevy Silverado 1500 EC with a 4.8L V8 2WD, standard transmission. I've always had A/C problems on this truck. Heater works fine, air blows through every vent. I have only a basic understanding on how the A/C system works. I've been searching for a good A/C maintenance book, as the Haynes manual for this truck doesn't have a good A/C section.
The air conditioner hasn't ever worked, I got the truck used with about 170k miles on it. It has about 220k or so now. I've done a little work on here and there on it but that's a different story.
When I turn the AC on, after a few miles down the road I start to notice a loud squeak. I thought it was just moisture getting into the belt spring causing the problem (I took it in to a repair shop when I first got it to get it fixed and that's what they replaced, it fixed the problem for a few months). It still does it if I try to run the AC.
The system holds refrigerant just fine, there does not seem to be any leaks and the pressure (45-50psi seems normal). I also replaced the pressure switch thinking that was the problem. The compressor will turn on for a few seconds than turn off and cycles two or three times then doesn't turn back on, even with the new switch.
I put a wire in there to bypass the switch for a few minutes to see if it comes on and it does, it will get real cold but still wont blow out any cool air in the passenger compartment (never does). Sometimes it will blow out hotter air than the heater will (I live in the south so that might be the problem).
Any ideas or suggestions on what I can do next or a good book/tutorial to learn? It's real hot in the south.
    HWN808
    HWN808
  • Who's Online   5 Members, 1 Anonymous, 1,063 Guests (See full list)
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
