Recommended Dealers For Service In Southeast Pa?
dan61psu
Hey everyone - brand new Silverado owner here...not even 400 miles on the beauty...but have a problem that I need to get fixed under warranty. What SE PA dealer do you all recommend for service? I hate crappy dealer service shops, and was very lucky to find an outstanding Mazda dealer with my last car...but that's no more :lol:
I am in King of Prussia. Carfagno, Fred Beans, Kelly, Thomas, Del are all nearby. Anone love or hate any of these?
I've heard good things about Fred Beans, but I'm not from that area. Sorry about the issue.
Might be out of the way but if you can find jones gmc they are top notch. It's were i got my 2011, and they are very concerned with the customers. They will go out of there way to make sure everything is right.
  • 1 month later...
I really can't comment on who to go too, but Thomas is definitely off my list of recomendations. I had an issue with a job they overcharged me for and all I can say is that I will never send another cent to Tom Ercalony (or however it is spelled). Jones sponsors allot at the Buck and was decent when I bought my yukon but I never had to take it in for service.
  • 2 months later...
I am in Conshy and I just brought my 2011 Yukon to Faulkner GMC in Trevose...so far so good but I have not received it back yet....I'm glad I purchased it used, I got rear ended on Ridge Pike 2 weeks after I bought it...so I went ahead and brought it to the dealer's body shop to have them install my remote start, repair my rear window defroster, and get a good 3 stage polish and wax done before winter. I will post back after I am done dealing with them.
I am in Reading, which is a bit of a hike for you I know but I deal with Geoff Penske GMC.... They were always fair with me.
Hey everyone - brand new Silverado owner here...not even 400 miles on the beauty...but have a problem that I need to get fixed under warranty. What SE PA dealer do you all recommend for service? I hate crappy dealer service shops, and was very lucky to find an outstanding Mazda dealer with my last car...but that's no more :)
Well..my review is in...body work was good...but they ripped me off on the detail..they did not polish the truck..but they charged me 160 bucks for a detail :thumbs:...I won't be back to Faulkner unless they make this right. I have a note in to the service advisor.
If you had any paint work done, they wouldn't have been able to polish or run a buffer over it for a couple of months. however in that case they shouldn't have charged that much for a detail...
I didn't know you were doing body work, I would have recommended the guy I deal with for body work. It would have been a hike for you but well worth the trouble. I'm not a fan dealership body shops.
they are refunding me the detail...the body work was just the rear bumper and the hitch..they removed them and repainted it...so they could run a buffer on the rest of the car...they were pretty easy about refunding me the money....the only reason I went to the dealer is because I wanted to have remote start added and I needed the rear defroster repaired since the previous owner managed to scratch the bottom couple of lines..so I figured since it was so minor I'd just go for convenience
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
