Broken Mirror Glass
So the passenger side mirror glass on my 03 Silverado cracked today. I ordered the replacement a few minutes ago. How hard are these to replace? Are there any tools or other parts I will need to tackle this job?
  • 1 month later...
If it is anything like the glass in the GMT900s all you do is tilt the glass all the way down (top part of glass is toward you) and then use something wide and flat to slide under the glass and apply a little pressure pushing the glass up. It should just pop out, first time you do it you want to go a little slow just to get a hang of the pressure needed.
The gmt-800 and gmt-900 mirror glass is held in differently!
The 800s glass is mounted on a plate with a "cup" and just snaps into
place.
The 900s glass has "fingers" on the rear of the glass/plate that slides/drops into "holes/loops" in the motor housing/mirror body.
You tilt the mirror down and pry up on the bottom till it slides up and out of the "holes/loops".
There are pics and instructions around here somewhere.
    ar0517
    ar0517
  • Who's Online   4 Members, 0 Anonymous, 524 Guests (See full list)
