Rough Idle 2008 5.3 Flex
RAT-ON
Guys, I have been searching on here and not really seen an issue exactly as mine and with a truck as new as mine. When in gear setting at a stop light (a/c on or off has no effect) my truck idles rough. You can't actually notice anything on the Tach, but you feel it in the truck. Pretty noticeable. I took it in while it was under warranty (around 30k) and they just said it needed a throttle body and injector cleaning for $$$$. I cleaned the throttle body myself since I have to do my wife's Envoy on an annual basis and ran some injector cleaner through it a few times and no change. I do not believe this is my issue and never did. I am not getting any codes, and have not driven another truck for comparison. Does anyone else's truck do this? Mine is the iron block, flex 5.3. thanks-Jason
I have the same issue, and needless to say it is aggravating. My truck idles rough but of course won't throw any codes. I guess nowadays without a code GM just says nothing is wrong. From what I've seen online the problem is widespread but GM currently won't admit to any problems. If you find an answer please let me know. I have an appointment for dealer warranty coming up to try and get some answers. I'll let you know if I do.
Guys, I have been searching on here and not really seen an issue exactly as mine and with a truck as new as mine. When in gear setting at a stop light (a/c on or off has no effect) my truck idles rough. You can't actually notice anything on the Tach, but you feel it in the truck. Pretty noticeable. I took it in while it was under warranty (around 30k) and they just said it needed a throttle body and injector cleaning for $$. I cleaned the throttle body myself since I have to do my wife's Envoy on an annual basis and ran some injector cleaner through it a few times and no change. I do not believe this is my issue and never did. I am not getting any codes, and have not driven another truck for comparison. Does anyone else's truck do this? Mine is the iron block, flex 5.3. thanks-Jason
when you cleaned the throttle body, did you look inside the intake manifold for any oil build up? it's possible there is some in there which is "normal" because the stock PCV system allows for some oil blow by. a can of Seafoam intake spray will clean that stuff up real good!
it's also possible your injectors are clogged with junk that standard injector cleaner through the fuel system is not cleaning up. i would recommend finding a shop that services cars using BG products. best stuff hands down to clean your fuel system and upper cylinders up! what they do is hook up a line directly to the fuel rail at the service port and pump the cleaner in right there at the source, so it isn't diluted down by your fuel in the tank.
http://www.bgfindashop.com/locator/index.php
if this fixes your problem, start filling up at stations who carry only top tier fuel! that means no more filling up at wally world or your local grocery store :dunno:
http://www.toptiergas.com/retailers.html
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
