New To Old Gmc Truck And Need Advice
I just got a 1978 Sierra Grande 3/4ton pickup for $500. Think I got a pretty good deal cause its only got 1 rust spot on it. I bought it for my daughters 1st vehicle. She wanted it, to my surprise. Anyway, i have a couple questions. 1- The fuel guage always shows way past full and never changes. It does have dual tanks at I think 44 gallons. 2- The temp guage, even on hot days like yesterday, 105 here, never gets even 1/2 way to H. Is this normal or should I get a new thermostat?
Oh and its only got 84k miles on it. Ive known the guy I bought it from for years and he is the original owner so im pretty sure it is 184k. Thanks for any help.
Fuel gauge could be sending unit, or bad ground on the sending unit. How long does the temp gauge take to get to half way? Quick way to test for stuck or missing thermostat is take the rad cap and start the truck when cold. Does water flow right away in the rad when you look in? If it does, the thermostat is stuck open, or just not there. BTW, running without a thermostat will still overheat, just take longer. The water needs to be in the rad for certain length of time to give up its heat. Water flowing too fast just does not have enough time to cool. If you really like the idea of no thermostat, go to your local speed shop (for cars, not for buzz) and get a Moroso water restriction kit and try the 5/8 size first.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
