305/60r18 Or 325/60r18?
DopdBrd
Ok so the truck has 275/70R18 Michelin's on it now with a RC 2" leveling kit. They spec out at 33.27 inches tall and 10.7 inches wide. They used to rub at full lockout but we cut the inner lip of the mudflaps so it doesn't rub anymore.
Wheels are the stock 18x8 All Terrain wheels.
I want to move up to a 18x9 with a +18 mm offset with a bigger tire. I'm looking at running the Nitto Terra Graplers and don't know which size to go with.
I've heard the 305/60R18 will fit with almost no rubbing. Now I know the 325/60R18's are wider and about 1/2 an inch taller than the 305/60R18's but I'd like to run a true 33" tall tire.
Also, I've seen people run the 305/55R20's with a 3 in body and leveling kit with minor rubbing. And being that the 325/60R18's are just about 1/2 inch wider, could I run those with a 3 in Body lift?
I'm just stuck with what to do right now.
I just put 285/65-18 Terra's & 18x9x18 XD Monsters on my 08 Chevy and I only clear by about 1/2" at full lock both ways. I was torn between the 285/65 & the 305/60 but I'm glad I went with the 285. 305's would have rubbed for sure on my truck.
No 325/60/18 will not fit. That is a 33.4x12.8 and will rub badly. You will need a 6" lift.
It is 0.2" taller and 0.8" wider than the 305/55/20 that people either trim or run a body lift to clear
    • Kudos? Are any of them desirable? Class leading (in any metric)?
    • Those are great questions, Bill. Our team looked into your VIN and it doesn't appear to have AFM or DFM. Please know, we take the personal and private information of our customers seriously, and we don't recommend posting your full VIN publicly. As for Auto Stop, some vehicles have a button to turn Stop/Start off for one ignition cycle. If the vehicle is equipped with the Stop/Start deactivation switch, you can push the switch to turn off Stop/Start. Stop/Start is turned off when the LED indicator on the switch is not illuminated. If you have any further questions, please visit https://s.chevy.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
