Slack In Rear End
I have a 2010 silverado 5.3 6spd auto i think 308 gears
i hear and feel a klunk some times when driving slow, then stepping on the gas
i just felt, it was between gear changes, but last night i cheched the drive shaft and felt quite
a bit of slack ( in neutral parking brake set) The u joints seem ok so it is comming from rear end
20,300 miles I take it easy and dont hot rod the truck
Any input anyone
Thanks
Harry
Any input anyone
Thanks
Harry
Why don't you ask the dealer since your still under warranty.
half to one inch slack is OK, I trained my foot, now it knows how to compensate with slack :)
Drop the drive shaft and pack the slip yoke splines with grease and reinstall. It will take up most all the slack your feeling :)
what if Grease enter in to Transmission ? - some says don't use grease :)
I would put some grease, but not pack
  • 2 months later...
You won't get grease in the transmission,... Pack the spline and you'll be fine. If when you put the drive shaft back on, and it feels tight as it's going into the transmission, as if the driveshaft got about 1/2" longer, then you did it right :lol:
there is a TSB from GM saying use only trans oil because there is nothing preventing grease from going into the trans
X2 take it back to the dealer and have them fix it. I had the same issue on my 2010 and the greased the splines and it seemed to work for awhile.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
