Please help. Started up the tahoe and everything was working fine. A few seconds passed by and then the message center went totally blank and the gear selector on the instrument panel (P, R, N, D, 3, 2, 1) is so dim that we can hardly see it. Everything else works normal in the instrument panel (spedo, pressure gauges, etc). The manual dimmer switch for the entire instrument panel is set as high as it will go before turning on the dome light. Any ideas are greatly appreciated!
Probably a stupid idea, but you sure the headlights aren't on? Have you looked that dash after it gets dark outside? With the sun out and headlights on, backlit things go very dim, analog gauges will still look the same, but digital outputs will be very dim with the sun out.
Thanks for the suggestion, Doug. Yes i have tried it with the headlights on & off and nothing changes. The message center is still blank. I have had the drls disabled since ive owned it and we drive it both day and night. Everything else works just like it should. I really hope I can figure this out because I don't want to have to take it to the stealership. I just wonder if a connection somehow can loose somewhere but I don't have a clue of where to start looking. Any more ideas?
I have checked all the fuses and everything is good. I'm totally baffeled at what's wrong here. Anymore ideas, anybody?
if you don't have all those fancy tools and service manual, then its time to visit your local dealer or someone who understand "- +"
if you have a good code scanner - hook it now and scan, see if you have:
DTC B3567
B3567 01: Driver Information Center (DIC) Select Switch Circuit Short To Battery
B3567 59: Driver Information Center (DIC) Select Switch Circuit/Component Protection Time-Out
Circuit/System Description
The driver information switches are normally open momentary switches. Power is provided to the
driver information center (DIC) switches via the instrument panel cluster (IPC). The IPC
interfaces with the DIC switches via 3 discreet circuits. The switch input to the cluster is pulled
low or grounded when a switch is activated. The IPC reads the voltage at the analog input to
determine which switches is pressed. The switch input to the cluster is set up in a resistor ladder
format for three of the four switches. The DIC switches include the PERSONALIZATION,
SET/RESET, TRIP/FUEL, AND VEHICLE INFO switches. A stuck switch or a short to battery
sets a DTC.
if you do have DTC B3567
1. Ignition OFF, disconnect the harness connector at the DIC switch assembly.
2. Ignition OFF, test for less than 1 ohm between the low reference terminal 2 and ground.
If greater than the specified range, test the low reference circuit for an open/high
resistance.
3. Ignition OFF, test for less than 1 ohm between the ground terminal 5 and ground.
If greater than the specified range, test the ground circuit for an open/high resistance.
4. Ignition ON, verify that all of the scan tool DIC Switch parameters are Inactive.
If any are not Inactive, test the appropriate signal circuit terminal 1 or terminal 3 for a
short to ground. If the circuit tests normal, replace the IPC.
5. Ignition ON, install a 3-amp fused jumper wire between the signal circuit terminal 1 and the
low reference circuit terminal 2. Verify the scan tool DIC Switch parameters, except the
DIC Fuel Info. parameter, are Active.
If any are not Active, test the signal circuit for a short to voltage or an open/high
resistance. If the circuit tests normal, replace the IPC.
6. Ignition ON, install a 3-amp fused jumper wire between the signal circuit terminal 3 and
ground. Verify the scan tool DIC Fuel Info. parameter is Active.
If not Active, test the signal circuit for a short to voltage or and open/high resistance. If
7. If all the circuits test normal, test or replace the DIC switch assembly.
my .02 cent worth :)
I had the same problem with mine, I took it to my mechanic and he referred me to a guy that did instrument cluster repairs. He got it fixed and gave me a warranty with it. It cost $125 but I didn't have to get taped at the dealer for a new instrument cluster. I'll post the link to his website... http://clustersurgeon.com/ hope that helps
im trying to build the DIC myself because the cheapest i could find was $90 on ebay. i found the diagram and all i need is 4 push buttons and three resistors. but in the diagram it wont tell me the value of the resisters. i have the pdf that i am attaching the link with here http://arrc.ebscohost.com/statics/p5/pdfs/vf_wiring/va277702.pdf#toolbar=1&navpanes=0&scrollbar=1
is anybody willing to open theirs up and take a look or even check the resistance from pin 1 and 3 from when each button is pressed besides the fuel/trip button?
  • 5 years later...
I have same exact problem. Can anyone post their final success story details? Seems like a very specific problem fix since the drive gear position indicator is dimmed to barely visible with all else blanked.
Get with this guy:
  • 5 years later...
This problem is caused by a bad LL2705 mosfet in the instrument cluster. It is a 75 cent part and it's located near the lower right corner of the DIC vacuum fluorescent display module. The cluster needs to be disassembled to accomplish the remove/replace/resolder repair.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,964 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
