This for all you owners that have done the DIC upgrade on your trucks. Im just wanting to confirm the part numbers as gmpartsdirect will not confirm since my vin number does not show the Dic option.
The numbers i have are 15947842 for the switch and 20935564 which used to be 25905504 and this was in black. Im going with ordering parts seperate since I can save around $20.
Ive done all the reserch I can on line and nothing tells me that these item are in black nor will gmpartsdirect confirm. Its a real pain trying to deal with them in email only. They do have phones dont they?
Your p/n's are correct, but why not just order the switch and cut out the panel you have? That's what I did, and I figure if I can do it....... Just a thought.
I took the liberty of copying some instructions on how to cut out for the switch, if anyone is interested:
"TIPS FOR THOSE WANTING TO CUT THEIR EXISTING DASH:
Remove the dash piece, then remove all the other parts from it; the headlight switch and the air conditioning vent both.
You'll need a Dremel (with an onion shaped bit; round, coming to a point), a triangular file about 3/8" to a side and a flat file about 3/4" or 1" wide. The wider the better for a straight, smooth cut.
Take your time; you've got all day. If you don't have all day, wait until you do.
Cut from the back with a Dremel and cut an opening smaller than you think it should be. Then finish up with sharp files. I only used the Dremel on the initial cut, then put it up. When you cut plastic with a Dremel, remember that speed only melts the plastic. I used speed setting 2 for the best cut without loading up on melted plastic.
Take your time; you have all day.
Make all cuts with a sharp file from the front to the back. This leaves the fuzzies on the back and easily trimmed with a sharp exact-o knife.
Take your time and be VERY careful with the finish on the face. Keep the files away from it and don't lay it face down to file on it!
Try to cut the opening with a slight bevel that leaves the front smaller than the back. This makes final fitting around the switch much easier.
Cut slowly and test fit OFTEN!
The short sides are easy to keep square, but the long sides are trickier. To make a nice straight edge on them, begin with an opening smaller than you'll need and work to get it square with nice straight sides even though it's too small. Take your time squaring it up at this stage. Then (here's the best trick yet) working with one edge of the opening at a time, use your triangular file to cut small notches all along the edge to the depth that you think you should be cutting. Make the notches a uniform depth and start/ finish in the corners, dividing the edge up into several notches. Then, with your wide flat file, cut until all the notches are gone. This way, your cuts will remain smooth and the edges straight. Be careful in the corners that you're only cutting the edge you're working on and not cutting with the side of the file.
TAKE YOUR TIME; you've got all day.
On FINAL fitting, get the height (top and bottom) right first, and then gradually widen the hole until the switch fits in without rubbing. A slight gap all the way around is better than tight so the buttons don't bind.
All in all, an easy upgrade. Cutting the hole takes some time, but at 2 hours and $45, your time is worth $22.50 an hour, so go for it. If you flub up, there are a ton of members here who still have their old plates; you should be able to find another one cheap."
Courtesy of belchfire.
Thanks for the reply. My nerves arent as steady as they used to be.
But I'm thinking about it. I used to do custom stereo installs
In cars but that's been a while. May still try tho. Like you said
I've got all day.
Ordered my parts today. Hope there is no problems considering
they were marked " No Return".
I bought mine from gmpartsdirect as well and they did come in black, they mark them "no return" since they don't stock the parts normally. Easy upgrade and you'll like the additional info.
How long did It take to come in?
They seem to take a few days to process the special orders, maybe a week or so?
When I search gmpartsdirect.com with the above parts number, the website says no parts were found matching your search. Do I need to email them to order the 2 parts??
When you go to that website, click on "Chevrolet Parts Catalog", agree to the proceedure, put your part numbers in the blank space, select "Chevrolet/Geo", hit "Search", and you ought to have some results.
Just for s***s and gigles, I tried to navagate their catalog for the seperate switch and Bezel and couldnt come up with anything with a parts discription. My hats off to the person that actually found the numbers!
    • I'm tangentially aware of what Harley used to be, back in my riding days, although I was into Italian sport bikes. Ducati seems to have gone the other way; still very expensive, but they've made a large subset of their bikes a lot more reliable and accessible, and they've diversified their lineup to include other riding sports too. IMO, a good example of where greed and growth might have also been beneficial to the consumer.   Although GM is charging a relative premium for its most popular pickups, I find that there are some excellent value propositions in its lineup as well.   The Colorado still strikes me as the most attractive midsize on the market, and also the most reasonably priced given capability and features. There's a part of me that wishes I would have bought one instead of my Silverado.   The Equinox ...I must be getting old. The ICE equinox is a great design IMO. Probably because it reminds me visually of an actual SUV aka an S Blazer. Underneath it's nothing even remotely close, but it LOOKS good. It's got all the modern features plus some at a very reasonable price. If I had to run out and buy myself a daily commuter to do everything except tow, an Equinox would be on my list.   It does bug me that mid-tier 1500's reach into the 50-60k range, and Tahoes and Burbs are even more expensive. Less than 10 years ago, dealers were sitting on rows of Tahoe LS and LT's for low 40's. You could even still find Tahoes with a front bench, still!
    • Big oil is raking in billions from the Iran war. Can it avoid Trump’s fury?   Remember I said Big Oil is 'Vertically Integrated"?   Even as they no longer own the majority of the "Pump" they still own the "Well". Crude price upward pressure does not translate into that same pressure on production. Pumping cost remain unaffected and the gap is pure profit. Even after subtraction of a minor, comparatively, lower amount from supposed, but not always, realized refining volume. Consumers hate war, Big Oil, not so much.
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
