Hid Bulbs Anyone?
i've seen a lot of support for spencershids.com on here and on GMFS.com
i might add there low beam/fog light bundle kit this winter which is only $270 and its all Phillips brand parts with a lifetime warranty.
Please dont do it.
They blind oncoming drivers and make your truck look cheap. To top it off they are illegal.
they are only illegal if they aren't within the proper color range... as long as they are somewhat white (not too blue or not too yellow) they will pass inspection.
and they only blind oncoming drivers when the installer does it half a$$ and doesn't readjust the lights.
Please dont do it.
If you dont replace the housing with a projector style housing that is designed to use HID bulbs then it is illegal. HID bulbs in a stock silverado/gmc reflector housing are illegal. period.
In order to not blind oncoming traffic you have to aim the projectors so low you dont see any advantage going with HID lights. To top it all off they make the truck look like crap. You might as well run a 747 size rear spoiler and NOS stickers all over the truck.
Please dont do it.
Just for the hell of it, what law is being broken? Is it a local, state or federal law? Just trying to get some credibility to your statements.
It is a federal standard, FMVSS section 108 to be specific, but every state requires that vehicles conform to FMVSS. So, it is a state law based on federal guidelines.
Here is a quote from Washington state highway patrol..
Vehicle Lights
Are high intensity discharge (HID) conversion kits legal?
No, in order for a headlight to be legal for use in Washington State, it must conform to the Federal Motor Vehicle Safety Standards (FMVSS) 108 requirements for headlights. The National Highway Traffic Safety Administration (NHTSA) has concluded that it is impossible to produce HID conversion kits (converting a halogen system to HID) that would be compliant with FMVSS 108.
Halogen equipment uses an electrical current to heat a metal wire coil filament to incandescence, while the HID conversion kit's light source incorporates a discharge arc to produce light. HIDs require a ballast for operation. Under FMVSS 108 Section S7.7 (replacement light sources), each replaceable light source for headlamps must be designed to conform to the dimensions and electrical specifications for the headlamp source it is intended to replace. For example, if an HID kit is marketed as replacing an H1 light source, then it must match the H1's wire coil filament size and location, the electrical connector size and location, and the ballast design for use with an H1 light source (which is impossible since there is no ballast).
NHTSA believes this equipment presents a safety risk to the public since the kits can be expected to produce excessive glare to oncoming motorists. In one investigation, NHTSA found that an HID conversion headlamp exceeded the maximum candlepower by over 800 percent.
Source:
http://www.wsp.wa.gov/traveler/pasfaqs.htm
I have them in my truck, they look awesome, work great and have never been ticketed, questioned or even flashed by another car. How exactly do lights that are only in high end vehicles make a vehicle without them stock look cheap?
Please dont do it.
Please dont do it.
Park your truck next to a mercedes or lexus..... Trust me, you will notice the difference right away :rolleyes: The way I look at it HID bulbs in a gmt-900 are no different than 5.0 badges on a v6 mustang. All show, no actual improvement to the vehicle.
I see several gmt-900s with hid lights in the reflector housing and without a doubt they are some of the worst lights on the road.
ok well I have seen them in a few trucks that look pretty good as long as your not putting all that other mexican looking stuff everywhere. so for the people that have them where can i find some of these.
read my first post, before we were so rudely interrupted by other people's opinions on the subject! :cool::rolleyes:
they should last the life of your truck if you buy the proper kit initially. the one the spencershids.com sells, like i mentioned before, comes with a lifetime warranty as long as you own the kit.
other places to look would be XenonDepot (forum sponsor), DDMTuning (reputation of slow shipping and horrible customer service, but the cheapest around), or VVME (haven't heard anything bad about them)
read my first post, before we were so rudely interrupted by other people's opinions on the subject! :lol::rolleyes:
Sorry to interrupt. I just thought it might be useful for people to know that the kits are illegal. Believe it or not, some people actually care about things like that :cool:
Please dont do it.
Just an FYI, my truck is parked in my garage right beside a european car with factory HID,s.....so ya, ive compared them extensively
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
