JP Custom's fog light kit
My Sierra doesn't have the openings on the air dam needed to install fog lights.  Has anyone installed the kit offered by JP Customs.  Is it easy to install and wire up?
Also the page states that you need to take the vehicle to the dealer to complete the installation, what exactly does the dealer do and will they give you any hassel over it?
Thanks
:D
The dealer has to "flash" the computer so it knows they are there.  Some dealers will charge like 20 bucks for it and some will do it for free.
They should be rather simple to hook up, the only difficult part is taking off the air dam, which isn't all that difficult in itself.
You shouldn't have any problems.
Or some dealers are A$$' and charge $70.  O'reilly - Tucson.
"Did you buy this truck from us?..."
The JP kit is the GM kit.  Real simple.  The hardest part is probably hooking in the wire on in the UEC underhood electrical center.  Although for me, the ground strap was not in the center of the bumper on the harness, so I had to hook it to the right side horn ground.
Of all of it actually, the hard part is paying to have BCM programmed to turn them on when it's just using a TECH2 and scrolling through a couple of menu's and changing a value to enable.
My truck didn't have the tow hooks nor the lamps.  I didn't cut out the back for the tow hooks when I installed them.  Still plenty of room to use them.  You'll have to cut out the opening for the fog lamps.  You can use a trimmer's knife.  Just take your time.  It can be done on the truck, but it looks like a toss up in labor to unbolt it and do the cut out on a bench.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
