Can't Figure Out My Stereo Problem
OK, I am calling on the expertise here because I have a problem with the speakers in the my truck. They sound like they are blown... but only part of the time. When the temps get really warm or really cold, my speakers start crackling or buzzing like they are blown. However, they don't do it all of the time. I can't determine if the speakers are blown, if the connections are old and rotting, or if the stereo output is bad. Any one with the same experience?
Thanks in advance!
I would have to disagree on the GM speaker bashing. I have had plenty of GM vehicles that were 5, 10, 15 years old that the speakers worked just fine. In fact for a factory speaker they kick ass especially with an aftermarket head unit installed. There is no way all your speakers could be blown at the same time. Sounds like a head unit problem. Is it a stock radio? Unless you been blasting that god awful rap whump whump music that goes by my house every night then you would need an upgrade to handle the bass requirements. ;-)
Not bashing, just how it is. Around gmt-800 years gm speaker quality went south or so my experience and a lot of others has been. Especially the non bose vehicles. And he never really said if they were all doing it or just some.
every one of my friends that has had a gmt-800 has had to put door speakers in. the drivers side went on all of theirs, maybe to blame the driver warning buzzes? if im not mistaken they come through the ds speaker. i know that my door speakers are a ticking time bomb, the way i listen to music, but what can you expect from a stock speaker.
and i am the one that drives by your house at 1 in the morning and wakes you up :cheers:
Aha , I got my perp! ;-) It must be on the newer vehicles. Probably Chinese made junk speakers. I have old vehicles: a 99 Sierra and a 2000 Malibu. So I guess I missed the cutoff. ;-) All my older GM cars in the past: Numerous Transams, Delta 88s etc.. jammed just fine also. Yes the warning buzzer does go thru the driver's door speaker. At least play classic rock if u are gonna wake people up! ;-)
Sorry, I should have clarified. It's only the passenger side front speaker. I did install some Kenwood 6.5 inch speakers last night. So far so good, and no buzzing or rattling. I'm running the stock head unit and bought just average Kenwood speakers since I will likely get rid of this truck soon and don't want to spend too much on it.
OK. Sounds good. Good luck!
On my truck, I went ahead and replaced all of them. I'm a sound enthusiast and do all my own stereo install. I had the same problem. When I took out the speakers, I couldn't help but notice the terrible construction quality. I had hoped that by this century, factory stereo had come away from paper cone construction. In a truck, you really need at the very least a poly-cone with foam rubber surround. The doors are subjected to lots of moisture on a daily basis, and simple logic will tell you that paper won't last very long. I replaced mine with JVC all the way around, and love how it sounds. Actually lost some lower bass with it, but gained a much crisper sound. (you can get the bass back with a small sub anyway). Went with two-ways in the front, and 3 ways in the back. It frustrates me sometimes how a company can spend so much money on certain things, then get cheap on others. As much time as I spend driving, I like my stereo to sound good!
I had to replace all of them in my 04. I run kickers ks speakers now. so far no complaints.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
