Truck Stuck In 4wd
whitextreme
I know there are other topics open on this but I could not find the answer I was looking for. 1999 Silverado 1500 with the Autotrac transfer case. The truck is stuck in 4hi if you push the 2hi button it flashes, tries twice then goes back to 4hi. And on the switch it will go into Auto but the scanner says it is in 4hi and the front is locked when you turn. The front axle actuator runs and the transfer case motor runs. I also know the switch is good. If I pull the ATC fuse the front axle unlocks so I believe that is working but correct me if I am wrong. I have access to a Snap On Modis I can access the transfer case but I cannot switch it with that either. No service 4wd light on and cannot command it on but I know the bulb is good because it flashes on for a second when I plug the fuse back in. I cleaned the main ground under the cab, no change. The transfer case is full, but I need to check the front axle is it psible that it being low could cause this? I checked all the connections on the transfer case all are clean and tight. I need to know if I take the encoder off can I try and operate it with the switch will it damage it? Also where is the ATC Module I looked all over under the dash and could not find it so I can check the connections there. Anything else obvious I can being checking? Thanks.
have it scanned by a real scanner,always shift while slightly moving in neutral(no driveleine stress) ,the encoder motor sensor is a common failure,
the front diff actuator is powered up by the switch on top of the t case not the encoder motor,,
good luck
    ballencd
    ballencd
  • Who's Online   4 Members, 1 Anonymous, 595 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
