Have a 2006 Silverado , 5.3. push button 4 wd, when engaged in any 4 wd settings my indicators light does not come on, checked fuses, what do i need to ck next.
Thank you.
Thank you.
ok, well thank u any way.
Thank you.
Bulb behind the indicator could have burned out.
Thank you.
i am guessing it would be a pain to get too?
I wish my 2011 has some type of indicator as to what mode your in . Its only on the little dial and not easy to see . Why didnt they put something on the dash/speedo area with all the other gadget lights .
Your talking about the lights on the switch itself, correct? I don't think they had any lights on the dash. I would say you would have to replace the switch.
The GMT 800s and 900s did not have lights in the dash, only on the switch, with the exception of the W/T models with the manual 4X4 lever on the floorboard, those had lights in the dashes.
Thank you.
So here's a silly question (my truck has the same set-up - little indicator lights on the button itself)...
Does your 4wd actually engage, just the light doesn't come on? Maybe the light is a response to indicate the 4wd is actually engaged and yours isn't hooking up.
Just a thought.
Thank you.
Just a thought.
the 4x4 indicator on the dash, not the button, might just take it in.
EXACTLY. You may see what you think should BE a light on the dash but there is no light behind it, there is no socket in the dash for that light. The only light is on the switch itself.
  • 5 years later...
I have a floor shifted transfer case, 4x4 works, but the dash light that used to light up indicating the front axle is engaged does not come on now. Is there a sensor for this on the t-case??
Sent from my Nexus 7 using Tapatalk
    juggernautusa
    juggernautusa
  • Who's Online   2 Members, 0 Anonymous, 1,350 Guests (See full list)
