Hello all, I have a 2013 Silverado 1500. This thing has had an oil leak for a bit, and was able to track it down. The 2 lines right above the front driveline held in by 2 10mm bolts. That gasket was seeping some oil. Pop the 2 bolts out, add the new gasket, go to tighten the 2 bolts and they will not get snug. now my small oil leak is a larger oil leak. Any advice? Can I block it off and do something external? Looking for options
thx
Killaz
I have had both. Both are good tires for highway and light off road use. The Wranglers are a little better in snow, but the Duelers seem to last a little bit longer and are smoother on highway. No complaints about either.
Looks like you're about there. The screenshot below is from the 2024 order guide but should be the same for yours. The only other item that came with my truck (which has VYU) that isn't specifically called out is the wiring harness (also below) which is supposed to prevent issues with the large electrical draw of plow operation. This wasn't installed and came in a bag with the upfitter switch kit.
Register a new accountSign in
