Bushwacker Fender Flares
I bought some Bushwacker boss pocket style fender flares, I have been seeing a lot of posts on other forums where people have had problems with the paint scuffing and wearing down there the flare sits on the fender even with the rubber backing installed to the fender flare, has anyone figured out away to avoid this? I have read about some people using 3m clear tape and some putting silicone on the seal.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
