Kyb Gas-a-just Shocks Vs. Bilstein Hd
My 2005 Z71 Sierra 1500 is nearing 50,000 miles and have noticed that when we are towing our 4500lb travel trailer that things get a little bouncy. Changing to 6 ply/Load Range C 265/70/17 tires helped a bit, but it still feels a little mushy with a load. Going to replace the red Tenneco stockers, but I used to have a 2000 Chevy S10 ZR2 off road with the factory Bilsteins......man, it road like a tank. I'm guessing the Bilsteins on it were part of the reason, I don't want to lose my nice ride on the highway - - anyone here with experience with KYB gas-a-just monotubes? Price is decent, and seem to be of good quality. Perhaps they would ride better unloaded than the Bilsteins, but offer better control than my probably worn out stock shocks?
I've used the KYB Gas-a-just shocks and the Bilstein HDs on my 2005 Silverado 1500 Crew Cab. The KYB controlled the ride well enough, but the fronts blew out in less than a year. The rears did not blow out. That being said, my pick-up is for farm use, which includes rutted out paved roads, washboard dirt roads, self-maintained roads, and sprinkler pivot roads that sometimes have sprinkler tracks that leave mounds high enough drag the frame on. Also, since this is a farm truck, and since I'm on rural roads, I've also seen many scale tickets of 19,000 lbs. when hauling fertilizer. Both the KYBs and the Bilsteins have done fine in those situations. I've had the same KYBs on other vehicles with great luck, so I believe they just weren't quite up to the task I asked of them. Currently I am running the Bilsteins with a 10 ply tire and I like the ride of the combination. Honestly, if you aren't on rough roads a lot, and I mean really rough, the KYBs with the 6 ply tires would probably work well.
I replaced my red Tennecos with Bilstein 5100s and love them. A firm ride, but not too firm, and excellent handling.
Thanks for the tips everyone. Still undecided, I'm tempted to try the Bilstein HD's (apparently now called the 4600 series?) they seem to be the favorite here, but sounds like I can't go wrong either way.
Hi, Kevin,
I have to suggest it, it's what we do! Air springs. If your truck is "mushy" with a load, you just add air pressure to get the ride where you want it. Reduce the air pressure when unloaded. They work! You're essentially adjusting the spring rate on the rear of your truck.
Hi, Kevin,
+1
air bags AND a set of Bilstein shocks.
Hi, Kevin,
+1
Firestone air bags. It's a better set up than the AirLift ones. I was looking into AirLift bags BUT they did not have the type I wanted for a 1500 truck, Firestone did so that's what I went with. Not a fan of mounting my air bags on the rear of my leaf spring.
Firestone makes a good kit. I will say that our kit for the half-ton does a great job, is one of our best selling kits, receives "five star" ratings on internet web sites, has a lifetime warranty, WILL support all the load you can safely put in your truck... and I believe you'll find it costs less. Not a bad deal....
+1. Did the same. Vast improvement in ride control; no more bouncing. The stock shocks were way too weak my 2500HD.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
