Turn Signal Problem
I have a 2008 Silverado 1500 crew cab and the right turn signal quit working. It works sometimes. I had the door open so i could access the fuse box and noticed that the dome light wasnt on either. When the turn signal works the dome light will also work. I need help its driving me crazy,although some folks say i dont have that far to go.lol
