2007 Yukon Remote Start With A Twist.
JD.JANSON
Howdy folks, I'm new to the forum and own my first GM that is smarter than I am. (My last was a 78 Sierra, go figure!) Anyway, Last week the CEL illuminated and the code is for a minor evaporative emissions leak. Haven't pinned it down yet but the code will not clear after replacing fuel cap. Yesterday the remote start function stopped working and I lost my XM signal. The remote start had been working even with the CEL (about a week) now when the remote start is pressed the fuel pump energizes then there is a click which I'm assumming is the pump de-energizing and no start. The truck starts fine with the key but when I first noticed the start function inop last night the XM signal was alos lost. The AM/FM is fine and I had the signal re sent and my account settings checked. So far no joy, any ideas would be a great help. Thanks
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
