NEW GM-TC IS HERE!!!!
Zane
Although the forum will not be getting a makeover at the time (more on that later), please check out the main page for all the all new GM-Trucks.com look!!!  :chevy:  :thumb:
Unfortnately this is only the 2nd time I've had interneyt access this week.  AND this computer is VERY, VERY SLOW, as is the connection.  So I've missed all of the updates and festivities, and I didn't even get to submit a picture for the contest like I had planned.  :D
However, tomorrow I will be back at my PC, and I will have alot of posts to read, so I can catch up on everything, and I can check out all of the cool stuff on the main page.
See you guys tomorrow.
    Dom Colussi
    Dom Colussi
  • Who's Online   5 Members, 0 Anonymous, 586 Guests (See full list)
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
