Blacking Out - Vinyl Cl Fence Paint
  • 2 months later...
Man...I think you did an excellent job on them. They turned out really nice. I love black rims.
Like your veterans info.."my Dad served 36 years including on the beach in WWII......thanks for your service!
cement blocks for jacking is a no no! i learned that the hard way when one exploded on me.
I like the black wheels. looks good!
:withstupid:
Please go buy yourself a good jack and some jack stands. The wheels came out good.
That was my first thougth too. :crackup:
Awesome thread. The truck wheels look great, thanks for sharing before and after and for gittin er done! I will keep this in mind for blacking out and restoring the look.
  • 3 months later...
I did the grill a while back. I didn't put nearly as much paint on it and I guess since it in direct contact with road debris it hasn't held up as well as the wheels. After taking the truck off-road a few times to reach fishing holes and things like that the wheels have a few more chips in then. As long as I leave them dirty that's not a problem. Overall for the price I am satisfied. I don't know that I'd use this kind of paint for a show truck though.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
