Interesting thoughts
Chev4Ever
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
A group of girlfriends go on vacation and they see a five-story hotel with a sign that reads "For Women Only." Since they were without their boyfriends, they decide to go in. The bouncer, a very attractive guy, explains to them how it works. "We have 5 floors. Go up floor by floor, and once you find what you are looking for, you can stay there. It's easy to decide, since each floor has a sign telling you what's there."
So they start going up, and on the first floor the sign reads, "All the men here are horrible lovers, but they are sensitive and kind." The friends laugh and, without hesitation, move on to the next floor.
The sign on the second floor reads, "All the men here are wonderful lovers, but they generally treat women badly." This wasn't going to do, so the friends move up to the third floor, where the sign reads, "All the men here are great lovers aand sensitive to the needs of women."  This was good, but there were still two more floors so, on to the fourth floor, where the sign read, "All the men here have perfect builds, are sensitive and attentive to women, and are perfect lovers. They are also single, rich, and straight." The women seemed pleased, but they decide that they want to see what the fifth floor has to offer before they settle for the fourth. When they reach the fifth floor, there is only a sign that reads, "There are no men here. This floor was built only to prove that there is no way to please a woman."
So guys, is this true or false?   :D
I said false, I'm sure we could please them, but, that takes a lot of time and effort.  I figure if I spent as much time trying to please a woman as I do working on my truck I would be able to.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
