'99 K2500 7.4 Vortec Rough Idle
Great forum, this is my first post here but a life-long GM owner!
Truck is a 1999 Chevy K2500 7.4 with 109k on it. It recently had an exhaust manifold replaced (drivers side). When its cold (as in first thing in the morning), it fires right up and high-idles for a few seconds and runs fine. After the first few seconds, its idles rough. The engine struggles to keep it above 7-800 RPM. When its in gear at idle (like a stop light), it struggles to stay above 500 RPM, and will occasionally stall. On any start after the initial cold start in the morning, it is hard starting. You have to feather the gas a little and it shudders but it will start then you have to give it a little gas or it'll stall. Driving, its fine as long as you are moving. It runs like a champ. Upon acceleration from a stop, there is a slight hesitation but once it's over that it runs flawlessly until it needs to idle at a stop again. I've been reading through the factory service manual, and theres more information in there on how to diagnose a squeaking serpentine belt than an issue like this. There is no CEL on and I scanned the computer for codes and nothing in the memory. I'm stumped.
What I've tried/done so far:
-New Plugs/Wires/Cap/Rotor
-Remove and clean Idle Air Control, test resistance and it falls within factory spec
-Replace PVC valve and vacuum line for it
-Clean Mass Air sensor
-Replace Intake Air Temp Sensor
-Run a fresh tank of gas with fuel injector cleaner
-Remove and clean throttle body
Add EGR valve to the list. Took it off to clean it and the mounting flange cracked in half. $90 later from the parts store and still idles bad.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
