Washing truck part 2
chevy4x4trucks
Well i couldnt take it anymore so today after my home depot trip i stopped at a self service car wash.  Put in $3 and sprayed all the junk off my truck.  Drove home.  Looks good now i have frozen water spots but thats alot better than salt spots.
Oh yea its 20 degrees out (warmer than saturday) and i think my hands are frostbite but hey my truck is pretty darn clean haha
I think I'll have to come into work next weekend to wash mine and change the oil.  We keep our stake truck w/ the 20' bed in the shop so I can just pull that out and pull my truck in.  They only heat it to 55 degrees on the weekend, but it's still a lot nicer than 10.
you didnt change the oil this weekend? Wimp out?
No, didn't have time.  I didn't even get to check out the door of my truck to fix the howling noise, which was really bad this weekend, even a little bit on the drivers side at 70 mph.  I finally crashed at 10 last night.  Hopefully I can do some stuff tomorrow since I have off of work.
You guys must change oil every 1800 miles or so, thats all you do other than wash your truck!   :D
Hey, every 2500, and I haven't washed my truck for over 2 months now and it looks spotless from about 10-15' away.
I think my truck got it's last wash 3 weeks ago.  This is the time of the year when I quit washing until March or April.  It's been down around 15 degrees the last few nights and I have so much road salt dried on it that it looks white, not green!!
i might feel the pain of u northerners, it might snow in b-ham this week!!  IM SCARED!  i have the trucks antifreeze filled up and i have the garage cleaned out to accomodate 2 of the trucks.  ill have to figure out a way to keep the other one safe outside
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,405 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
