2003 4wd Silverado Bouncing @ 35-40mph
shahan110
Any help would be great, my 2003 4wd extended cab longbed is a great truck, no issues other than a bouncing problem around 35 to 40mph. Universals in both front and rear driveshafts have been changed and so have the front hub assemblies. Tires have been balanced twice and the truck has been aligned, very little play in driver side tie rod end, none in the passenger side. The bounce does not affect the steering and seems to come from the middle of the truck. Carrier bearing has also been replaced,all of the above replacements has taken place in the last 6mos. I've seen a lot of postings about vibration compliants but no real answers, again any help would be greatly appreciated. Thanks travis
