Replacing Power Steering Fluid
Does anyone know how to replace the power steering fluid on a 2004 gmc serria 2500. I have never replaced power steering fluid before and would prefer not to go in blindly.
The easiest way is to suck it out with a turkey baster and refill. Do this for the next three times you change the engine oil and it will pretty much cover it.
[url="http://www.gm-trucks.com/forums/index.php?showtopic=138300"]Best Way Ever To Change Power Steering Fluid, Never thought of it[/url]
    Brendan C
    Brendan C
  • Who's Online   6 Members, 1 Anonymous, 1,138 Guests (See full list)
