Driveline Issues?
I removed the rear driveshaft to have it rebalanced and u joints installed. Problem is I didnt mark the rear diff yoke in relation to the front diff yoke. Does it matter? Does the front diff yoke and the rear diff yoke without driveshafts installed need to be parallel or is simply having the driveshafts properly balanced eliminate that issue? Will I have issues with vibrations if I dont install the driveshaft exactly as it was removed? If so who will professionally do it?
Just put it together and see how it feels (and mark it this time). If you have a problem, you can always try different orientation.
I just looked at this again. If your talking about the pinion yoke on the axles, it shouldn't matter at all. If your talking about a splined slip yoke on a drive shaft, the u-joints have to be in phaze.
Mark
