Body Lift Or Trimming
Hey guys I have everything I need for my lift and tires to go in just need to find a shop to do it, but with my rims they are rubbing and I know for a fact when I lift it it will still rub. Should I add an extra 2 maybe 3inch body lift or just trim it? Give me suggestions on the brand if you think I should go with the body lift! Also its on an 08 Sierra Denali so I want to do everything the right way
Body lift. They are eaasy to install and keep a fairly stock feel to the handling (except for a little more body roll). Ive never fet good about cutting up a truck. I use Performance Accessories products, but I know a lot of guys use Zone stuff. They both make a 3", PA makes a 2" and Zone makes a 1.5". I was looking at the Zone, but went with PA because it looked a little simpler to install. Prices were the same for bothe brands in a 3" IIRC.
That's what I was thinking too I feel terrible when I cut up my truck. My overall lift should look even better now with the added height!
I have a PA kit and it's great. I prefer that added height so I think a 3" would look great. BTW, PA only makes a 3" for the GMT-900.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 258 Guests (See full list)
