Hypertech Max Energy
I recently purchased a Hypertech Max energy tuner for my 2011 sierra. Please anyone expecting anything from this tuner beware! I installed the regular tune, and noticed that on acceleration it was pinging. so i filled up with 89 octane. this didnt help out the pinging at all.
as for the shift points, they are barely noticable
shift firmness, that worked decent in my truck
fuel mileage, seemed to pick up a mpg if i didnt step on it because the pinging was driving me insane. it wasn really loud. if the radio was on you coudlnt hear it, but you knew it was there.
SO! moral of the story, if you think you are going to save 170(VS BB) and buy some POS cookie cutter tuner that IMO would have destroyed my truck, THINK AGAIN. Im lucky that summitracing.com is taking my tuner back after i used it. it could have been a $380 mistake, add on the fact that i am in contact with BB and am going to spend more on the autocal
can anyone tell me what needs to happen with the autocal? do they ship me something that monitors my trucks computer? then i drive like normal and they make a tune to see what can be fine tuned? so then i ship something back and they mail me a tune? the long process is why i went with a cookie cutter tune
Travis you should have called our tech dept and we could have done a tech sheet and got that corrected if it was pinging. This is very unprofessional to post something degrading our company when we dedicate our time to tuning for horsepower and fuel economy for our fellow customers. Many of the forum customers on here use our products in there vehicles with very good success, hope you get your money back and sorry it didnt work out for you.
AGREED! I hate when people buy a brand new product, test it, then bash it without contacting the manufacturer first. Companies always need to know feedback, otherwise how can they fix/improve on it?!
you dont want to read my opinion, and i dont want to read yours, so why dont you kindly crawl back under your rock you came out from.
as for stating my OPINION, pretty sure we havent been stripped of "freedom of speech" JUST YET.
as for hypertech, i am sorry for being unprofessional about my post. perharps it was made out of spite. my future opinion reviews will not be made out of haste. if i could edit that post i would.
  • 3 weeks later...
I installed a Hypertech on a 2009 6.2 and the results were quite good. The programmer raised the shift points by 500 rpm, the Rev limiter by almost a 1000, and added noticable HP. More important, my 0 to 60 times (using a G-tech) dropped almost 1/2 second. However, the program did not change the Shift Firmness or the fan temp. I talked to Hypertech and they said these options were not available for the this motor/trans combo. Regardless, the results were quite good.
I purchased a Hypertech Max energy and I noticed a bump in power and a bump in MPG with the standard tune. I also have ZERO pinging. 2007.5 4.8L
I would recommended this programer to anyone. I am very happy with it.
Jason.
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
    • Injector is being sent off today for rebuild and I estimate I'll have it back in 10 days or so.   It may not be the injector...of course...now that I've torn down the intake again. But, let's rule out the injector and replace those spider legs that have been almost rubbed through.   The truck has always had negative timing and I'm reading "normal" timing at warm idle should be +16 or so. I'm negative 16 to 25 or more, and it's always been like that since I bought it.   A light turned on upstairs last night in the old noggin. Rare, I know...   This will be wild, if it turns out to be the cause!   In 2001, according to the old service documentation, the muffler was replaced. Why? I have no idea, it wouldn't have been rusted through by then. But they did a crappy job.   In 2019, another shop replaced it and noted the prior install was poorly done on the work order. "Exhaust system vibrates on crossmember". Except...I guess they just left it be? I believe the husband, the couple who were original owners, had passed by then. Maybe she said it's just not worth it to have the exhaust system fixed and declined repairs. Very few miles were driven between 2019 and 2025.   The exhaust system vibrates heavily on the crossmember and you can feel it and REALLY hear it, even today. Not always, but at idle, it gets going pretty good sometimes.   What if....   ....What if that's enough to trigger one or both of the knock sensors? Could it be tricking the sensors into sensing knock, so it's pulling timing aggressively? Pulling timing heavily means it's firing after the piston reaches full height which means incomplete burn which means the O2 sensor is sensing a rich condition, which means I've been chasing my tail, and what I thought was an inconsequential problem (janky exhaust) has been THE issue for this truck for 25 solid years?   That would be wild. Maybe it IS wild.   The service documentation thereafter, for years, shows visits for rough idle, replacing O2's, replacing the cat, replacing plugs and wires, a misfire condition, like they could never solve the issue. The injector has been replaced 4 times in 80k miles, that's just crazy.   The secondary theory....   The engine has clearly had a leak at the front seal for a very long time (the greasy trench...). I think the truck changed hands quickly ~2025 because there's Napa receipts from someone I don't recognize in the ownership history. They apparently replaced the timing cover seal, and they did a terrible job. There's RTV smeared all over and the leak I had reduced to a weep by snugging the front oil pan bolts is now a leak again.   HOWEVER....I read about replacing the crankshaft position sensor. Any time the ckp sensor is disturbed or timing cover is removed, the truck requires relearning, and that can only be done through a bi-directional scan tool. Skippy with the RTV probably didn't do the relearn procedure is my guess. His scan tool is lost in a pile of RTV goo somewhere.   So, it's very possible the sensor has been disturbed and the truck is just running on the old learn data but not setting a code for anything. The distributor has since been replaced and so has the camshaft position sensor, so all bets are off for that thing.   In the theme of one step forward, two steps back, I returned the accumulator for the AC. The gal I've been working with at O'Really's has been great. She refunded it under manufacturer's defect and we compared it to the replacement I ordered, and sure enough, the replacement is machined very differently (and a gauge actually fits on it!).   Got it home, installed it, started vacuuming it down.... and I couldn't get good vacuum.   The high side service port, where I replaced the old GM ball valve suspecting that was a source of the previous leak....well, I've clearly exposed whatever pre-existing crack in the line where the service port is welded, and made it much worse. Blessing in disguise? Except there goes another $25, now I'm waiting for a replacement AC line.   In 10-ish days ALL the parts will be here. Rebuilt injector, new exhaust system, new cat, new high pressure AC line.   Oh, did I mention the squeaking ISN'T coming from the AC pump? The truck still squeaks when started, and there were words after I started it with the new AC pump installed. But, there was more to replacing the AC pump for just a squeak. A truck with good working AC is something of value, for the comfort alone.   I've ordered a new harmonic balancer because, 30 years is a good run for one of those. Rule it out. The squeak may be something more sinister, though. I'm worried about that ckp sensor and if it was shimmed correctly, or if the timing set was installed correctly. The squeak may be coming from UNDER the timing cover.   At this point, once I get it put back together, I'm thinking I'll take a 50 mile victory lap and then promptly put it up for sale. This truck is cursed. Betty, from beyond the grave, doesn't want anyone messing with her Blazer. Or maybe she's getting revenge for 30 years of shop visits with that thing.
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
