2011 Silverado - Tire Fitment ? fellas.... HELP
teej750
I Have 265/65/18 duratracs with my bilstein shocks....no issues
I hope there are no issues...because that is the stock size.
If you want the look, pay the piper! Cut or bend that inner fender! I was running 33x12.50x20 with no problems all I did was slice about 2" off the plastic. Then I bent that tab of metal behind front tire towards the rear of truck about 1" and that's it! Just get you some under coating and clean where you bent or scratched metal and apply! Like they said you ain't gonna see it!
i had 285/70/17's on with a readylift leveling kit and i just switched to a 285/45/22 and havnt rubbed with either
I'm new to this site 1st post...I'm thinking about putting bigger tires on my 2011 silverado. What do I have to do with the tire sensor? Do I have to change it or what? Or will it be ok ?
  • 3 years later...
Hi new here but recently did a little shoe upgrade on my truck and wanted to share. I have a 2010 Silverado crew cab z71. Over the winter I did a 2" front leveling kit to my rig to get rid of the rake. Well that led to a ton of web surfing to find an answer to my question as to tire size I can go with to fill in things a bit more. Well truck came stock 265/65/r18 around a 31x10.50 tire. They didn't fill in wheel wells enough for me after the lift so I finally pulled the trigger and bought her some new shoes. I went with 275/70/r18 mastercraft axt by cooper. 33. Something x like 10.6 put them on factory alloy rims. Personally I can't get any more tire in there without rub at 45 degree wheel turn. And I don't want to cut yet but I love the look, and they fit. Can't rate tires quite yet but they are a little luggy but yet extremely quiet on road. Hope this helps answer if someone is looking. Also buddy has 2010 GMC 1500 crew cab z71 no leveling done all stock he put bfg tko2 , the new style all terrain, he went 275/70/r17 on his stock rim turn out to be like a 32" tire. Great look but he does have very slight rub at 45 degree wheel turn but nothing terrible and I believe it may be only on his mud flap.
    whenindoubtuseahammer
  • Who's Online   3 Members, 1 Anonymous, 557 Guests (See full list)
