Lift and tires killed my mileage and performance
I dont expect miracles... Im just hopin for better performance and amd maybe a tweek more mileage. I feel now for me to have the get up and go that I want, I have to have to heavy of a foot
Justin tuned my truck today, took about 45 minutes total. He disabled the AFM, changed shift points and it was well worth the money. I'm ordering the AutoCal too so I can data log and get license for two vehicles so I can use it on my wife's car.
Not to sound stupid , but what is the AFM? Did it change the personality and feel of your truck?
AFM - Automatic Fuel Management is how I know it. It transitions the motor from 8 cylinders to 4.
Stevens11, real close, same meaning. It's Active Fuel Management. Not really noticeable unless you change the exhaust. If you ever heard a 4 cylinder metric with a fart can, that's what your truck with at least a cat back performance exhaust will sound in V4 mode. As for the driving, its pure pleasure, no throttle lag, if you ever wish your truck would shift up/down with no jerking or skipping down more than one gear (which it seems to do when you mash the gas and after the lag) get the blackbear performance tune. Bite the bullet, drive to a live tune or go the autocal route. 100% sure you will be satisfied. I say all this and I just met Justin yesterday.
I have a cat back system and know exactly what your talking about. I have been e mailing Justin and I live in southern Nj. He isnt going to be anywhere near me.The auto cal setup he can e mail me the updates and I can install them myself... Other than that Im a little unsure how the whole thing works
Glad you made progress! I've been thinking about doing the Autocal deal, I want to keep v4 mode capability over sound though. It does sound a lil ricey, but with the radio on and the Bose crankin, I don't really notice it. No complaints from people in the backseat either
The AutoCal email tune option is just as good. I basically did the opposite. I got the live tune, now I'm ordering the autocal. You may ask why? That way I'll have my stock tune and can data log and have Justin tweak it if I add any mods, etc......
  • 3 weeks later...
BB with the autocal is the way to go, if not you can wait for an in person tune from justin. your other option is East Coast Supercharging www.eastcoastsupercharging.com they use EFI Live and are VERY VERY good at what they do, and they are close and always around.
IMO BB is better, but just throwing another option out there since ECS is in south jersey.
It you're looking for good mileage with a lift and big tires, you're SOL. A lift WILL decrease mileage some, greater angles on drivelines and slightly more air resistance on underdody. Tires hurt a lot though. A 4:10 regear helps quite a bit, but helps driveability more than anything. You can't expect near as good of mileage with tires that weigh 3 or 4 times a normal sized lighter tire.
Thats not entirely true. My 03 5.3L with 4.10 gears and 35" tires still averaged 14-15mpg and 18-19mpg highway If I kept the speed below 70mph. If your geared properly you should still get decent mileage.
  • 2 months later...
  • 1 month later...
Well finally ready to do it. Putting a K&N on this weekend and ordering the autocal as well. Im excited about the possibilities!
Congrats, and welcome back Budd.
Thanks Matt,
Hope your doing well? What part of Texas are you from? We were looking at Houston and Austin for possible relocation...
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
