Heated Seat Install-Need Help ASAP
I am installing GM Accessories Heated Seat Kit and am having some trouble....the instructions are horrible!
Anyway the Truck is a 2007 2500 HD Duramax Crew Cab 4x4 LT with Leather
The Kit is the GM Accessories Kit that is brand new in the box, with the Dash Mounted Switches.
1. I am having trouble confirming, which element plugs into which part of the seat harness, GM didn't label which plug went to which element making this a complete pain, especially if you are wanting to hide the wires when doing the installation. (For Example, how do I know I have the elements hooked up correctly to know which command will be done when I press the "back only" heater button???)
2. I have ran all the wires and made the connections, however I am confused about the connections that go to M3, and also the extra wires. I have attached a picture below, and I see one plug(2 Pin Plug with Yellow Wire), and then there is a standalone yellow wire just hanging out, then there is an additional plug (2 Pin Plug with Purple Wire w/White Tracer), and then there is another standalone Purple Wire w/White Tracer just hanging out.....where do these extra wires go? The instructions say to reference "Service Procedure 1706444"...
Overall the seats are done, and look nice, however I'm unsure if the elements are hooked to the seat properly, and also I'm confused about what to do with these wires...can anyone help? The truck is in the shop and tore apart, I'd like to finish up tomorrow if possible!!
There's a long forum topic at:
http://www.gm-trucks.com/forums/index.php?showtopic=78133&st=60
If I remember correctly, everything but the seat elements were made to go to a specific plug based on different tabs or shapes. The switches also have to go in just one way so they control the correct element. The instructions are poor, but I made a "word" document as I went along, just send me a personal note with your email address.
I had the dealer install mine. On the drive home I turned on the driver's side back and the seat bottom warmed up. I took it back and it took them less than five minutes to fix the problem so think they switched the connectors around under the seat. Hope that helps.
IIRC, those wires go with the empty connector that comes with the kit. The service procedure, I think, simply refers to how to populate the connectors.
On the pages I scanned I left some hand written notes,maybe they will help? (the thread my info is in is referenced above). I also have some stuff here that maybe of help (from the post above):
The two connectors are labeled M3 in each 56-wy connector. The pictures suck here very bad. There is an M1 row of pins on the junction block to help you locate M3 (third pin on row M). One of the 56-way connectors has a yellow wire and one has a purple wire. The instructions warn to only do one at a time but they are wire tied to the wires feeding each connector so unless you are color blind (and I am a little) you can not screw this part up. To remove the wires and connectors, use the small screw driver or pick to pop off the red plastic 'banjo' lock that is securing the pins in the one side of each 56-way conenctor. These red locks will simply pop and slide out. This is very important as the electrical connectors will NOT come out without the locks being released! Once the red locks are released and laying safely out of the way, then you can use the small screw driver on the front of the 56-way connector to lightly push the other release, it is very easy really. The yellow and purple wires you have released then go into two small electrical connectors supplied with the kit. The wire contact ends themselves will slide into the plastic connectors easily, you will feel a tiny click. You can then slide a gray (on my connectors) lock over the wire and it will be locked into the electrical connector. IMPORTANT: It might be helpful to match up the connector cavity needed to the matching plug on the new harness! The supplied connectors have two holes each but you only use one on each. Pictures 38 & 39 show the connector and lock, although mine was shaped slightly different and the lock was not able to be released fully from the connector, it simply slid into place to lock. Both of my new connectors/matching harness connectors are behind the big junction block, there is plenty of room.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
