Possible BDS issue
While I was leaving wally world tonight I was making a left handed u-turn and went over a bump at the same time. It was at this point it sounded like my front end was grinding and my traction control light came on until i completed the turn. This isn't the first time this has happened, it's usually when I am making a hard turn and the wheels feel like they are almost hoping as turning. Any thoughts as to what it could be?
I don't believe it's a tire clearance issue as I am only running 305/55/20's.
The truck was re-torqued yesterday and the alignment was re-checked, everything came back fine.
how many miles? check your wheel hubs, cv shafts, ball joints, tie rod ends, i too have a bds lift i get some tire rub but i have 35x12.50 (measures 13.50) trail grapplers on a -12 offset rim... are you sure you're in 2wd?
The skipping issue is common with lifted trucks and has been discussed on here with the Rancho kit IIRC. Mine will skip too sometimes. The grinding is a different story though, and it could quite possibly be your tires. What are your wheel specs?
when you make a hard turn the stabilitrak will automatically apply the brakes which is probably what the skipping and light was it also can make a grinding sound. it could also be your tires rubbing on the inner fenders
    liddlera
    liddlera
  • Who's Online   4 Members, 1 Anonymous, 664 Guests (See full list)
