MPG vs. changing weather
I've only had my truck for about 6 months and I've tracked fuel economy on every tank so far. It just started getting cold here in Michigan about a 5 or 6 weeks ago. Until then, I've been averaging 16 MPG pretty consistently, which I've been content with. Once the ambient air temps dropped below 40* F, my fuel economy took a nose dive. I'm now getting 12 MPG.
Is it normal to see a 25% decrease like this? I could understand 1-2 MPG, but 4 seems ridiculous. Do you other northern folk see a fuel economy decrease like this around this time of year? I really hope it doesn't get any worse once we start approaching 0* F.
OP. I'm also from Michigan and this will be my 2nd winter with the truck. Between auto start, winter blend fuel, longer to heat up, occasional auto 4x4 switch, and other dumb drivers I generally see a mpg loss as well. Summer - 16.5mpg. Winter - 13.5. Its not 25% but it's close. Auto start kills about 1-2 alone for me.
Winter blend fuel, running a bit richer at start up, remote start can all play in to kill MPG's. Also, have you checked your tire pressure since the temperature dropped? 25% seems a little steep. How many miles on your vehicle? When was the last time you changed the air filter, plugs, & wires?
How does the remote start kill your mpg's?
This is the first truck I've had with RS and I don't see any difference in mpg's. Is it because your can just turn it on inside the house letting it warm up and that's what kill the mpg's or something else?
I haven't checked tire pressure since putting new tires on a couple months ago. I'll do that soon though. It has 182K on the clock. The K&N element was cleaned and oiled in July. No telling about the plugs and wires. I have a set of plugs in the garage that I'll install this week and I just ordered wires today. I doubt this stuff would make much of a difference, but it's worth trying I suppose.
I assume it has to do with excessive run time. Mine spends a minimum of 20-30 minutes running on the RS every day this time of year. That's bound to add up to some noticable/measurable fuel comsumption throught an entire 32-gallon tank.
According to your posts, you changed tires about the same time as your mpg change. Some tires offer more rolling resistance than others. This could be 1 factor. Winter blend fuel, colder air and engine warm-up are other factors
Correct. But if I remember correctly, I did put a few tanks of fuel through it on the new tires before it got cold, and I was still getting my 16 MPG. I replaced my worn A/T tires with new A/T tires, so I didn't expect to lose any fuel economy from the tire change.
I lose a few mpg's but I know it's all my own fault. I tend to start/idle in mornings so kids don't climb into a cold truck. Also idle throughout the day more often such as after lunch before going back to work. Of course if you don't do anything like that I'd say winter gas blend, double check your tire psi as everyone has said.
There is your answer. Idling cold for 20-30 minutes a day, plus cold weather driving, plus winter blend gas....
yea, i let mine run for 10-15 so that may explain that extra 1mpg worse youre getting than me. id rather pay an extra $10 in gas a month and have a warm car though, so its worth it.
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 839 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
